In the staircase at my home an electrician installed a LED strip in the handle. I can dim the lights to desired intensity using a springloaded switch and a timer turns on the light in the morning and off at night.
The problem is that every time the light is turned on it's on full blast which is really annoying in the morning.
Can I solve this using the hardware I have without having to call in an electrician?
Driver: LED dimtrafo MDR 12V specs
Timer: Theben TR610 top2 specs
