I picked up a tv console today knowing that it had some light damage. There’s hole punched out of the top of the piece.
Item Photo
Damage Photo Close
What would be the best way to fill in the hole? What’s the best way to match the finish of the original piece and the repair?
  • And have it look aesthetically correct? Not easy to do. Hence, the low price. – Harper - Reinstate Monica Aug 12 '18 at 17:53
  • Is this a large unit that you plan to secure to the wall and convey with the house when you sell it? The reason I ask is that stuff that is part of the house (which includes cabinetry), is on-topic, but furniture repair isn't. So this will become part of the house, right? :-) – fixer1234 Aug 12 '18 at 18:18
  • I wonder if the dent can be steamed out.... seems a bit of a risk though. – Jasen Aug 13 '18 at 9:42
  • Voting to close. Possibly off-topic (unless we call it woodworking), but questions remain and OP hasn't been back. – isherwood Jan 15 at 15:43
You can clean out the debris, carefully salvaging the surface pieces, use filler to adhere the remnants back in position and to make it level where there are missing pieces. If it is too motley a collection of fragments, just clean out the debris and patch the hole with filler.
Then if you are REALLY artistic, you could carve the woodgrain pattern in any visible filler to match, and paint it to match. But that will still be noticeable because the texture will be different and you will never get an exact color match.
The alternative would be to patch the hole, then refinish the top, either with paint to make the top uniform (may not hold up to wear) or something like high pressure laminate.
Another option: there are craftsmen who specialize in those kinds of repairs. They work for the insurance companies or stores and fix damage that happens to furniture when it is delivered or when you move. That might be expensive.
You might be able to buy a new top from the manufacturer. That kind of furniture is usually assembled without glue, so you should be able to remove the old top and reassemble it with the new one.
If you can live with the dent (aren't too bothered by the appearance or can just cover it with one of the things you would put on top), the simple solution is just to stabilize it so it doesn't get worse. Find a marker of a close color and color the exposed material (hard to tell whether it's wood or MDF). Then use some glue that dries crystal clear (like the clear glue from Weldbond). Put a little on a cotton swab and cover the dented area. It will end up glossier than the rest of the top, but it will keep the broken pieces from disintegrating and rough edges from being chipped.
