I just purchased a new florescent fixture with a fancy plug connector, and I will be replacing an older fixture that is connected (twisted with wire nuts), so I have no place to plug the new fixture. Can I just cut the fancy new plug off, and twist the fixture wires to the house wires, like the old fixture? Thanks
4Is it suspended or mounted to the ceiling? Could you attach a picture?– Retired Master ElectricianCommented Aug 12, 2018 at 1:53
Any twisting of house wires must be done inside a junction box. If you don't have a junction box, this is a codevio. If you do have a junction box (commonly an "octagon box"), they make a lid for that box which has cutouts for a receptacle. Total cost: $2. Standard wiring for a lot of warehouse/industrial spaces.– Harper - Reinstate MonicaCommented Aug 12, 2018 at 19:19
Add a comment
1 Answer
In the same situation , I put a receptacle in the ceiling fixture so T can simply plug in the new light and it would be easy to change fixtures in the future.
