I have a shower stall in my basement guest unit. As it's only used occasionally, sometimes the P-trap dries out. Other than remembering to add water periodically, if I haven't had any guests or I anticipate a long period without use, can I fill it with oil or antifreeze? What are my options?
Is there something I can do to avoid having the trap dry out during intermittent use? Or is there an alternative type of trap I can install during an upcoming renovation?
I'm also considering removing my wash basin (it gets moldy and takes up a ton of room) and adding a stand pipe to catch my AC condensate, but I am worried I'll experience similar issues.
    I've heard that you can top off the water in the trap, then carefully add a tiny amount of mineral oil (a few tablespoons); the layer of mineral oil will prevent evaporation. I've never tried it, though, and don't know if it actually works, so I won't post this as an answer.
    – fixer1234
    Aug 6, 2018 at 7:55
  • It makes sense that that might protect a stand pipe evaporation (provided it doesn't dry out on the sewer side, but in the case of a shower trap, once someone goes to rinse the shampoo out of their hair, all that oil will be emulsified with the excess soap and wash down the drain.
    – virtualxtc
    Aug 6, 2018 at 7:59
    Right. It's only intended to stop evaporation when the plumbing isn't in use for a long time. After the shower is used again, you would need to repeat it for the next "dry spell". It's one of those things that seems harmless to try.
    – fixer1234
    Aug 6, 2018 at 8:09
    I just have a calendar reminder item “run basement shower” on the first day of the month. It makes me think about whether anyone’s used it recently, if not, usually with a day or two I’ve run the water for 10 seconds to replenish the trap.
    – Tyson
    Aug 6, 2018 at 8:46
    In commercial applications we used what as known as a trap primer. It is installed on your water line and drips a small amount of water into the trap to prevent gas from escaping through the trap. I really don't have any other information about cost, application or availability, but may be worth checking out. You really need to have an informed plumber give you more information. Aug 6, 2018 at 12:49
5 Answers 5
There's two solutions to this - a trap primer and baby oil.
A trap primer is a device that has a tube running from a fixture to a seldom-used drain. Whenever that fixture is run, a small amount of water is diverted to the trap to fill it. There are also standalone primers that run based on a timer and don't rely on a fixture.
Since oil floats on water, baby oil will coat the water in the trap and keep it from evaporating. Next time you notice the trap is low, top it up and add some baby oil.
Adding a trap primer will probably be disruptive and expensive - I'd go with the baby oil.
You can use any oil, but baby oil (or plain, unscented mineral oil) won't go rancid as a food oil (vegetable oil, canola oil, etc) eventually will. Plain unscented mineral oil is sold as a laxative in most pharmacies and some supermarkets.
    I'm about to do a remodel, so the trap primer sounds interesting.
    – virtualxtc
    Aug 7, 2018 at 2:25
Simple answer - fit a rubber plug to the drainhole. Same kind of thing you'd use in the bath or sink.
That will slow/stop the P trap from drying and even if it does dry, the plug will be a seal of its own.
Fit it after the guest has gone, as part of the general cleanup and reset. Anyone using the shower will realise why its not draining and pull the plug.
The biggest inconvenience is possibly standing on the plug in bare feet and it hurts, so pick a lay-flat style if you have any choice.
    This is a good dollar store store style answer!
    – virtualxtc
    Aug 7, 2018 at 6:17
Pour a couple of quarts of water into the drain and put one of those thin, circular, rubber drain stoppers on the shower drain. This may keep the trap charged for months. Or just set an old plastic bucket on the drain or invert a bowl on it.
Do not put ordinary auto antifreeze into your drains. The active ingredient is ethylene glycol and it is toxic. There is a practically non-toxic antifreeze using propylene glycol as the active ingredient which is used to winterize plumbing, but even that is unnecessary for your case. Mineral oil might not be good for PVC drains, and is probably not recommended by the city sewage dept, but in small amounts probably would not be harmful to most plumbing and to the sewer treatment processes, but is unnecessary. If you would use it, I would use mineral oil USP from the pharmacy since it is getting into the sewer stream from its use as a laxative.
As far as removing the lavatory, I think code requires one if there is a toilet. Anyway these are an essential element of a bathroom for personal hygiene. Do not under any circumstances remove the existing one without replacing it! You could perhaps install a smaller one if you can find the right one, but this might require a surprisingly costly renovation. If the trap on the lavatory is smelling from sewer gas, then that trap may be drying out too.
Every couple of months (after you pour in some water to charge the trap) pour a half-cup of Clorox into each drain and chase it with a couple of cups of water. this will kill mold in the traps.
Where does your a/c condensate drain right now? It is not a good idea to drain a/c condensate into the drain of a lavatory because it makes an irritating, sleep-disturbing sound.
  • I have used olive oil in our mud room since we never hose it down because we take our boots off outside.
    Aug 6, 2018 at 13:38
    The waste water treatment authorities don't really want an significant amount of fat or oil in the sanitary sewer. I think stoppering is the best solution. Aug 6, 2018 at 14:28
    Olive oil or other food grade oils at what the city recommends in my area it only takes 2 tablespoons to provide a seal over the water so the water won't evaporate. Better than a methane explosion from the trap drying out. I was surprised how many times this happens after the first one I heard of in my town.
    Aug 6, 2018 at 14:39
The oil trick is more temporary than the rubber stopper. Oil evaporates too, just more slowly than water, so it just forestalls the inevitable.
I have a seldom used drain where I use the rubber stopper recommended by Jim Stewart. It keeps the trap water from being exposed to drier air, so it doesn't evaporate. Pour a little bleach into the trap first so that you don't get mold growing in their either. I've gone 2 years without using it and the water was still there.
  • Doesn't this assume I have to anticipate when there will be a lack of use?
    – virtualxtc
    Aug 7, 2018 at 2:26
    Won't you know when your guests leave, @virtualxtc? Or, just stick the stopper in the drain and remove it before a shower, then replace it afterwards.
    Oct 11, 2023 at 15:51
I was unsatisfied with all of these answers as they would require me to actively anticipate my drains usage. So I did some more googling and more success in my research this time as any of the following would satisfy the requirements of my question:
1) Floating ball style sealing devices that act as both a back flow preventor and an evaporation mitigator Integral Drain with backflow / evaporation ball
2) Valves that use the weight of the water above them to open and close: enter image description here
Sure Seal
Quad Close Stink Stopper
Green Drain Super seal
3) Water free P-trap Replacements
enter image description here Hepvo
It's doubtful that #3 would be good for a floor drain. For the stand pipe #1 and #3 seem like are the best options.
