I have a vent for the microwave-range that goes from an interior kitchen wall to the outside of the house. I need to re-locate this, but I can't move the exterior vent fixture. It currently comes in the house with a 6" galvanized ducting pipe about 18" long before it transitions to flex duct.
Is there an immediate 90 degree elbow that I can put directly on the outside vent so that as soon as it comes in the wall, it goes vertical within the studs, instead of jutting into the house so far? I would like to essentially go up with it about 8 inches and then transition it back to the flex pipe.
