Sorry i'm in a bit of a pickle here.
So this particular lock style uses plastic with metal on the inside. As far as I could see there was no traditional latch mechanism to trigger to open the latch on the door handle. After removing the plastic to get access to the metal, I found that there was no pulling it at all. The plastic and the metal are conjoined with a small metal rod right about where the plastic meets the wood. You'll see it about halfway in and out assuming the picture worked.
I have no way in or out and since this is a rental property would like to avoid action-movie style kicking the door down guns blazing. The other side of the handle with the lock is inside of the bathroom.
I can't find a single guide on the internet regarding this specific door handle so I'm out of ideas. Thanks for any suggestion
