I WANT to add low voltage led lights around the rim of my pool. I think IP68 rated are the best. The pool is above ground and is 30x15 so I would need about 5ea 16ft strips. I would like to use the multi color lights and have one controller if possible. Could I use one hefty 12v power supply and run separate leads to each section?
Any ideas and recommendations would be appreciated.
