I have to transmit audio from point A to point B and all I have connecting those two points is a composite video cable (RGB).
(History. Old setup was: Computer->AVR[Video->Projector by composite, Audio->Speakers]. New setup: Chromecast->Projector(Video->Screen, Audio->Receiver by composite?)
Can audio be carried by the composite video cable?
closed as off-topic by mmathis, Tyson, ThreePhaseEel, Daniel Griscom, fixer1234 Aug 5 '18 at 10:30
  • This question does not appear to be about home improvement within the scope defined in the help center.
If this question can be reworded to fit the rules in the help center, please edit the question.
    yes, one channel per plug. – dandavis Aug 3 '18 at 6:24
  • No adapter necessary? – Wynne Aug 3 '18 at 11:31
    RCA jacks are used on both component video cables and composite RWY A/V cables, so no adapter should be needed. As far as I can tell, the only difference between the typical RWY and the RGB cables is color codes. – Chris M. Aug 3 '18 at 11:39
  • 4
    I'm voting to close this question because it's about AV not home improvement – mmathis Aug 3 '18 at 14:49
  • you might need an adapter, depending on your input and output connectors. RCA is a common one for analog audio, as is a headphone jack. You can get headphone to stereo RCA adapters anywhere, even places like walgreens. – dandavis Aug 3 '18 at 15:31
If I understand what you're doing, you want to put the chromecast on the projector on the ceiling, and use two of the RGB to run the audio out back to the receiver.
Yes, it will work, I have done this many times to re-purpose cables installed in home theater and commercial AV. The RGB cables for component video (RGB) and composite video (yellow) are just 75 ohm impedance coaxial cables with RCA ends, same type typically used in red and white for stereo audio. The color coding only matters to the person plugging things in.
Per google support (https://support.google.com/chromecast/answer/6280276) you'll need a 3.5mm to RCA stereo adapter cable.
  • I agree the wire is the same, the plastic covers make it easy to know the cable connections at each end. – Ed Beal Aug 4 '18 at 16:00
