I recently purchased a used pool table and light from an auction. I didn't realize how heavy the lighting fixture was until after I got it home. There are three glass refraction globes that weight 8 pounds each. The total weight of the lighting is about 35 pounds. There are three metal hanging chains on the main rod to hang from.
I need to hang this above my pool table. The ceiling height shouldn't be an issue, but I'm worried about the weight. I have access to the attic, as it's going in my house. I was thinking about placing some 2x4's across the joists in the ceiling and then using some threaded rods to extend down past the ceiling. I assume I can find some hooks or something to screw onto the ends of the threaded rods. Then I can use the chains on the light to hang on the hooks.
I'm really not sure what the best approach is for hanging this light. If anyone can point me in the right direction, it would be much appreciated. I don't want to make large holes in my ceiling. I also want to damage my ceiling or cause sagging.
EDIT: Adding photo. I should also note that, I already have one electric box mounted in the ceiling (with power), but it is not centered to the pool table. It's about 3 ft away. I was thinking of running the power to the current box. Maybe I should just mount a new fixture and move the existing power to it.
EDIT 2: I may be missing some mounting parts.
