The previous owners of our home did a foundation repair to fix two large cracks about 10 years ago (it is covered by a lifetime warranty). The repair was very successful, but the epoxy plugs remain.
In an effort to improve the efficiency of the home, I want to apply rigid foam (xps - 2" on walls, 1" on floors). I am left scratching my head however on how to do this on the wall with the epoxy plugs. I've included a picture below of the plugs for reference.
The best option I can think of is to strap the was with 2x2's or 2x3's first. Thoughts?
I'm not familiar with epoxy repairs, but I'd guess that those holes were drilled to allow material injection and the plugs merely retained epoxy while it cured.
Can I remove the injection ports after the completed repair?
Yes, but first wait 24 hours to allow the LCR injection resin to harden and fully cure. A hammer and chisel will easily remove the injection ports, and the crack sealer can be sanded, ground off or painted.
https://www.polygem.com/lcr-faqs-frequently-asked-questions
I'd grab them with a big ol' pliers and bend them back and forth a few times, breaking them off. A recipro-saw with a fine-toothed blade would also work.
Otherwise, if they're not too long, just press your foam onto them. A little persuasion and you can forget they were ever there. The lost insulation value is trivial.
  • Regarding the latter point. Are you sure? Some of the plugs are almost 2" long.
    – pim
    Aug 1, 2018 at 19:00
  • Probably not, then.
