I am looking to repair a driveway damaged by transmission fluid (ATF) in the photo below. As you can see the driveway has pitted and cracked where the fluid was standing. Once winter comes I expect the freeze/thaw cycle will wreak some real havoc.
cracked and pitted asphalt due to contamination with ATF
There are two other small holes in the driveway caused by a floor jack, which I intend to fill with one of the products available at home improvement stores.
Is there a good way to dig or scrape up the ATF contaminated asphalt so I can use the same product to fix this damage? Or is there another preferred fix for this kind of damage?
With a diamond blade on a gasoline powered saw you could remove a neat square out of the pavement, and then fill with fresh concrete and/or asphalt. Such saws can usually be rented.
