Can someone help me understand why my chandelier has a positive, negative and ground wire, then something I've never seen: 2 sets of blue and white wires and 2 jack holes inside connection pad? I'm assuming they go inside the jacks for over heating but I'm not an electrician.
Thanks in advance, Francesco
enter image description hereenter image description here
  • if it's a 2-bulb chandelier (or a 2 cluster) then there is a set of wires to each bulb (cluster) – ratchet freak Jul 31 '18 at 12:00
  • We need another view of the fixture. As posted it’s not possible to know if there’s one bulb or twenty. – Tyson Jul 31 '18 at 12:20
  • Hello, and welcome to Stack Exchange. Where did this fixture come from? Did it come with instructions? – Daniel Griscom Aug 1 '18 at 18:35
The black, white and green/bare are for you to connect.
The blue/white are internal to the appliance to route the current to the various place it is needed (each bulb). It's got nothing to do with over-heating.
|improve this answer|||||
That Eurofase F-20KAS2-05 fixture uses low-voltage halogen light bulbs.
This means that somewhere hidden in that big cover is a power supply - that's where the blue wires go.
The blue wires are connected to the white wires (which run down the shaft to the light bulbs) with those white crimped-on caps. These are not intended to be fiddled with by the user/installer - they're permanent & non-removable.
The only wires you need to concern yourself with are the black/white/ground wires which supply power to the hidden low-voltage power supply - black to hot, white to neutral, ground to ground.
