I've got ceilings that need to be painted, and I don't have any ceiling paint but I have a bunch of leftover white paint from painting my walls. Is there any reason I shouldn't just use my leftover wall paint for my ceilings? The wall paint has eggshell finish and the color is actually slightly off-white (white with a hint of cream)
1 Answer
Ceilings are typically painted with a flat sheen paint, as it's good at hiding (or at least not highlighting) imperfections, nor does it need to be particularly durable. Those two qualities tend to lead to a less expensive paint, and if you can save money where you can, why not. If you've already got some leftover (non-glossy) paint, there's no real reason not to use it. I wouldn't use gloss or semi-gloss on the ceiling, but eggshell should be OK.
1Exactly what we were taught when I sold paint at Sherwin Williams ages ago. Also, flat paint tends to reflect light in a more general and diffuse way. Jul 30, 2018 at 20:02
Some ceiling paint has a special (purple) dye that fades as it dries which makes it easier to see what you have already painted. Also I think most ceiling paint is a flat pure white so that all the rooms are painted with the same ceiling color which simplifies touch up work. Jul 30, 2018 at 21:36
For ease of use the same color on wall and ceiling is a plus. However paint appears darker on ceiling due to light refraction. Some choose to use the brightest flat white possible. Ceiling paint usually is very poor at resisting marring.– KrisJul 30, 2018 at 22:39
All correct (+1) except I would use only totally flat paint, no "eggshell". Jul 31, 2018 at 4:38
