I'm interested in opening the wall between the kitchen and the "Dining Room" in an apartment that I'm renting. Before I pitch this to the landlord, do I need a permit for making that kind of modification in a non load-bearing wall? realistically I would only be cutting through one 2x4 and building a header in for the span.
    Seems like a location is critically relevant here.
    Jul 30, 2018 at 16:09
  • 4
    I'm voting to close this question because permitting questions are off-topic
    – mmathis
    Jul 30, 2018 at 17:20
  • Question is general enough to be useful, no need to close.
    – gregmac
    Jul 30, 2018 at 18:39
    I would get a permit because it's rented. Because if the job is done illegally, you're not on the hook, the landlord is. Attention to details like this is a powerful sway. Once I made huge points with a landlord when I accidentally broke a $40 custom fixture glass, called him up, "hey, where do you buy those fixtures?" and fixed it on my own. Jul 30, 2018 at 18:43
Assuming you are in the US, you generally don't need a permit for cosmetic changes. Everything else you do. To find out for sure contact your local government building department.
    I would say nearly everything else, and what needs to be considered here is any electrical and plumbing in the wall that would need to be moved. As a counter-point, I don't know of any jurisdictions that require permits for low voltage wiring (telephone, cable, network), and I think you're generally okay with minor changes to HVAC as well (eg, moving a vent).
    – gregmac
    Jul 30, 2018 at 18:37
