I have 1” black iron pipe running just shy of 40’ to a manifold. The manifold then has one run of csst coming off it to my furnace. I then have 4 more ports I can run off for new appliances as I convert them to gas. My electric dryer just went up I would like to replace it with gas. The run would be about 30’. Is 1/2” csst big enough for that run the dryer is about 22000 btu. Thanks in advance.
1terrylove.com/forums/index.php?threads/…. Answers here indicate that your 1/2” gas line is more than adequate to support your dryer even on a30’ run – Kris Jul 31 '18 at 19:23
I concur, 1/2 inch gas pipe is adequate for the dryer. The only thing I would like to add Is, did the gas company run a 2 psi meter to your home? an easy way to tell is if there is a gas regulator at each appliance. This is a pretty common practice in the state I live in. If it is a 2lbs system, you'll need to have a regulator added to the new appliance. Just something to be aware of.
Wow in the 5 states I have lived in 3/4 psi has been the limit for residential. When my dad was alive we had a gas kiln for drying wood and that was 2 psi but the gas company removed that regulator and put in a standard one some years later for safety reasons. Probably because it had not been used once the exotic woods were all used. – Ed Beal Nov 3 '18 at 15:36
