I have the following spigot and it appears that there is no way to access the piping that leads to it. I am used to the typical silkcock style but this one I've never seen before. Is it removable from the front?
PS: The reason why it needs to be changed is that it leaks through all the holes in the front which renders having a hose pretty much useless.
  • I googled this for you: woodfordmfg.com/woodford/wfdindex.html Commented Jul 29, 2018 at 18:10
  • Thank you for the link. So this does explain the splashing. Is there a way that this can be replaced with a quarter valve from the outside. On the other side, there is just a cement basement wall so I wonder how was this installed.
    – Michael
    Commented Jul 29, 2018 at 19:50
There appears to be a repair kit for this: http://www.woodfordmfg.com/woodford/Troubleshooting/25%20-%2027%20Troubleshooting.pdf
The model in question is 20 but the 25 kit is supported by it. It can be replaced from the front.
