I have a closet that I've modified to be a vanity area (I have 2 closets and aren't interested in having a titanic wardrobe). I pulled off the closet doors and the closet clothing hanging hardware and made a floating desk.
The only thing I need is power for the blow dryer and lights I plan on adding. I've decided that a old work 3 gang box would be best (Having a duplex for electronics, and a light switch for the overhead lights).
Desk:
I plan on using the typical daisy-chain tactic between existing outlets in my room.
Closet Considerations:
I was reading some other posts about installing outlets in a closet (And objections to it, notably regarding closets being used to store objects and the outlet/objects plugged into the outlet being crushed, and I don't think that will apply here since this area will not be used for storage.
Code Considerations: I'm not entirely certain how to wire the outlet up to code, and could certainly use some instruction with regard to this. I've chosen 14 AWG Romex wire for the install (Same as the already existing outlet). I know that I've seen contractors use electrical tape to wrap the screw terminals around the outlets, but what else would be involved in this installation? I also need to run wire behind the wall to get from one outlet to the other. I plan on following an install similar to for running the wire(https://youtu.be/eSMUnuoxdZQ).
What are the minimum requirements to wire a new code-compliant outlet like this in a closet?
