I have a Ariens self propelled lawnmower that I happend to hit a iron marker(pipe) with. When the blade hit the pipe, the lawnmower jolted and the engine stopped and I have not been able to start the engine since then.
I took a look and the blade still intact except for a nick on the edge; still has a balanced spin ( meaning it doesn't hit the walls of the mowing case ) when I spin it by hand. It has fresh gas and oil. There are no spills anywhere.
I don't what else to do or where else to check. Is there anything else i should check before taking it to be repaired? Thanks!
closed as off-topic by isherwood, Tyson, ThreePhaseEel, Machavity, mmathis Jul 27 '18 at 13:02
  • This question does not appear to be about home improvement within the scope defined in the help center.
If this question can be reworded to fit the rules in the help center, please edit the question.
    mechanics.stackexchange.com/questions/32965/…. Try this link for an answer. This is off topic for this site. – Kris Jul 25 '18 at 21:12
    Thanks for the Link. I didn't know about that website. – Baratier ErebusDuHalm Jul 25 '18 at 21:32
    Many walk behind lawnmowers have the engine directly coupled to the mower blade. It's possible a good solid slam could break the crankshaft. – Harper Jul 26 '18 at 2:06
The flywheel key is made to shear when things happen like you described. I had it happen a few times over the years. Pull the top of the motor off, remove the flywheel replace the key, and reassemble.
I hit a two inch pipe stub that was sticking up out of the ground with a push lawn mower. The mower stopped totally dead instantly with a huge thrack of the blade against the pipe.
I coundn't get it restarted because the shock had dislodged the spark plug connection. Once I discovered that and reseated the spark plug cord I did get it to startup and it tried to run. Unfortunately the drive shaft had become bent and the whole mower vibrated so bad that I could barely hold onto the thing.
Needless to say that resulted in a need to buy a new mower.
