When we bought our house it had an opening as shown in the picture below.
There is white wood trim on top of the rough framing.
The trim is nailed to hide the 2x4 stud that forms the frame of the opening.
The opening inside the trim is 46" and the rough opening width is 47-3/4". The rough opening height is 81-1/2".
What door option do I have for this space?
I checked and it seems that most prehung doors are either 48" or 42". I think the first is too big and the second is too small.
Has anyone had experience with this?
  • I think you're confused. Almost never does one see a residential door wider than 36", and only on the interior if handicap accessibility was a priority. Even 42" is comically huge. You'll want to frame down to a more standard 30" door opening or consider something like an accordion screen.
    Jul 25, 2018 at 17:51
  • What about a sliding door option or a barn door? Wouldn't that work?
    – Michael
    Jul 25, 2018 at 18:03
  • Sure. Just not a single hinged door.
    Jul 25, 2018 at 18:17
  • I think there are also double door options, I just had a terrible time finding anything for 46''. The market has only 48 and 42 options.
    – Michael
    Jul 25, 2018 at 18:44
  • I can't tell what that space is intended to be, but a bypass closet door could work if you're set against reducing the opening. They're not so dependent on opening size.
    Jul 25, 2018 at 18:49
I have a rough opening in my house that is the exact same size (47³/⁴ by 81¹/²) which is a very odd dimension, leading into a downstairs makeshift bedroom. A pretty small room but I still wanted to cover it up with some kind of door. I couldnt find a double door set that could fit in the given width and I didnt really want a barn door because I wanted a locking door knob with a key. After a few hours of looking around on the internet, I think I found a decent solution. (https://bit.ly/2wUdzM5) Two of these 22 by 80 doors will leave me with about 3³/⁴ wiggle room which I think will work out fine. Assuming everything will fit fine I hope this helps anyone with the same problem. I will update this if anything goes wrong but im sure this will work. I just ordered the doors and will try to remember and post pictures of the before and after.
  • Hello, and welcome to Home Improvement. Thanks for the answer; keep 'em coming. And, you should probably take our tour so you'll know the details of contributing here
    – Ack
    Apr 6, 2020 at 0:57
    Please don't use link shorteners, some might construe that as spam...
    Oct 5, 2020 at 12:16
That looks like an excellent candidate for a pocket door. Since that is a meeting point for a few openings, hiding a door is going to look much cleaner, save space, and allow you to open and close with clearance.
An economic door that I have used that would fit this opening is - https://www.homedepot.com/p/Johnson-Hardware-1500-Series-48-in-x-96-in-Pocket-Door-Frame-for-2x4-Stud-Wall-154080HD/100658068. You will obviously have to cut the height but this is pretty easy to do.
  • The only drawback to a pocket door is, as I understand it, you must peel back the finished wall surface to get the door installed, whereas a standard swinging door can be simply pushed into place, removing the existing trim at most. I agree that a slider seems to be the ideal candidate here, it's just that there are installation complications...
    Oct 5, 2020 at 12:15
