I am pulling wire from my basement for an outside receptacle. I drilled a hole through the rim joist. To secure pvc pipe from inside, I wanted to install a junction box on inside, and use a metal box with middle 1/2 in opening that sits on the joist with the PVC male plug.
Is it OK to have a junction box on rim joist code wise?
You can place the box on the rim joist as long as it is not covered at a later time the box needs to be accessible.
  • Thanks Ed. I am not going to cover it. It will be accessible.
    – cppdev
    Jul 26, 2018 at 0:45
