I'm replacing a smart light switch with a regular rocker switch. It looks like the previous owners had a neutral wire pulled down for the smart switch, making a total of 2 black wires, 1 white (connected to neutral), and 1 bare copper (I assume ground). The rocker switch only has 3 inputs, can I safely ignore the neutral wire?
Also, does it matter which black wire goes in which backstab connector?
Edit, pictures:
- wires https://i.stack.imgur.com/c8S3j.jpg
- box closeup https://i.stack.imgur.com/GMcck.jpg
