Tank is pressurized at 90psi. Attached to 50 feet 3/8 hose. Tool end of hose has a standard quick coupler. ( so its closed )
Is it "okay" to disconnect the male quick connect fitting from the tank? I understand the air in the hose is pressurized and air will come out, how bad can it be?
