So I've got a 2x10 Ledger attached to a concrete wall. I have a double 2x10 joist that needs to connect to the ledger. I have a joist hanger for this but the installation requirements say to use 16d nails (which are typically 3 1/2" long) to connect to the ledger. How can I do that if the ledger is only 1 1/2" thick? Will the nail go into the concrete? Are there shorter nails?
    FYI, joist hangers are almost never installed with 16d nails. They're usually hung with "teco" nails, as described in the answers below. They're roughly as thick as 16d nails, but of a length appropriate for a single two-by ledger.
    Feb 19, 2019 at 14:48
  • 16d on a 2× not heard of that before, Teco yes.
    Feb 19, 2019 at 15:24
Joist hangers resist loads in shear, not withdrawal. While a 16d is more common, full resistance is developed in a 2x.
Simpson Strong-Tie makes a short nail that is 1 1/2” long x 9 ga. diameter.
Oh, and be sure to order the nails treated (galvanized) or stainless steel based on the type of pressure treated ledger.
  • 16d are not more common. It would be a massive effort to put 8-12 full-size framing nails in dozens or hundreds of hangers by hand. Almost everyone uses nails like those you've described, except in some girder situations. We call them "teco" nails, probably after an early manufacturer.
    Feb 19, 2019 at 14:51
    @isherwood you are correct about the Tico nail origins. hansenpolebuildings.com/2013/01/tico-10d-common-nails Feb 19, 2019 at 14:56
  • @UnhandledExcepSean TICO ???? I’m talking Simpson. Where did TICO come from?
    – Lee Sam
    Feb 19, 2019 at 21:24
  • @LeeSam did you not read the comment directly above mine? Feb 19, 2019 at 21:24
  • @UnhandledExcepSean Exactly. My “Answer” referred to Simpson and now Isherwood and you are concerned about Tico. Why?
    – Lee Sam
    Feb 19, 2019 at 21:40
There are shorter nails, but there are also short screws available. I'd go with the screws every time. For example these are made by Simpson and fully approved for use with their hangers.
Note that the #10 screws are the correct size to replace 16d nails.
