Our shelf in the shower cracked off four big pieces but the bottom of the shelf stayed intact. Now we have a jagged bowl shaped shelf left collecting water whenever we shower. Any recommendations on how I can keep the shards level while they cure? Should I fill the hole with foam of some kind and then put epoxy glue on the shards and hope that the foam doesn't move too much until they're cured?
