Testing with non contact voltage detector I get intermitent positve where flexible conduit enters garbage disposal even with breaker off. Is it a false positve or is th switch bad? Reset triped while in use
closed as unclear what you're asking by The Evil Greebo, Tyson, Machavity, mmathis, Daniel Griscom Jul 18 '18 at 21:00
Please clarify your specific problem or add additional details to highlight exactly what you need. As it's currently written, it’s hard to tell exactly what you're asking. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
  • ncvd's aren't 100%, by any means; lots of false positives, a few false negatives – dandavis Jul 17 '18 at 21:19
It may be a phantom voltage, that you are seeing, many disposal units have a Allen key you can turn to make sure things are free if it turns + the reset on the disposal motor is set and the breaker is reset if it still won't start check the wiring at the switch. Disposals pull a large starting current and if back stabs were used it may have burned one of the stabs if you pull the switch out and it starts working get a new switch before it burns the wire off.
