When setting post in hole, should you put it a small brick or mixed concrete in the botoom before setting post?
    you did not say what material the post is made from .... put concrete in bottom of hole so that the post does not touch dirt – jsotola Jul 15 '18 at 20:23
  • I usually add gravel so there will be room for water to drain if I use anything other than concrete. – Ed Beal Jul 15 '18 at 21:28
