I would like to buy a pressure activated water valve (for irrigation), so that when the water pressure is above P1, the valve will turn on, and when water pressure drops below P2, the valve will shut off. Does anybody know any product that would serve this purpose? Thank you.
I don't think it can be done without external power. There wouldn't be enough energy to stop the flow once it started. So it must be some electrical means involving pressure switches and solenoid valves.– Dan D.Jul 14, 2018 at 21:48
Try this products.danfoss.com/productrange/refrigeration/water-valves/… I know that is refrigeration - you might be able to use for irrigation - but hey if they make them for refrigeration - I am sure you can ask about irrigation. There are electronic systems available - if you are looking for that - write back and state that electric is fine, Industrial systems use them all the time..– KenJul 14, 2018 at 22:44
For irrigation, why do you need two set points instead of one? Also, is P2 higher or lower than P1?– fixer1234Jul 14, 2018 at 23:14
1@DanD. This can trivially be shown to be false. A spring loaded check valve will open at a pressure greater than opening pressure, and close at a pressure less than closing value. The spring stores the needed energy.– vidarloJul 15, 2018 at 8:51
1 Answer
What you are looking for is generally called a Spring loaded Check Valve. A spring presses against a ball which seals the line. Flow only occurs when the pressure can overcome the force of the spring. But that only gives you a single pressure to work with.
See Check Valve for an overview
Once the pressure has overcome the spring, how will the valve then close? May 15, 2019 at 17:08
@Peter M Check valves are used for preventing water from flowing backwards when the water pressure drops to low. ( such as in line between a well and a pressure tank ) Normal water pressure pushes against the valve and spring opening the valve, if the water pressure drop to low the spring pushes back and close's the valve so water dose not get pushed back towards the supply side. May 15, 2019 at 18:15
