I have a room built under the roof on top of the garage, so eaves are directly behind the side walls. I removed the skirting boards to install the a new flooring and realized that there is a sizeable gap (up to 4 cm / 1.5") between some of the wall plasterboards and subfloor.
I'd love to put some insulation in there as these gaps would definitely allow the transit of cold air from eaves into the room. I would prefer the insulation to be removable if needed, so expanding foam is probably out of the question. What else could I use?
  • I would spray foam at the crack as it will seal the airspace.
    Commented Jul 13, 2018 at 23:05
Hard density foam board is probably your best option. You can get 1.5" panels and cut them to size and get an R-7.5. enter image description here
You could take batt insulation and compress it but batt insulation works best when not compressed and compressing it down to 1.5" would yield a lower R value than the rigid foam:
