I have three groups of outdoor house lights and one group of landscape lights. They're on four separate light switches. The house light switches are located indoors in separate locations far apart, and the landscape light switch is located outside far from the other three.
A year ago I replaced all four switches with timers to increase their usefulness and convenience. But it's turning out to be a hassle to adjust all of those timers every few weeks to stay in synch with seasonal daylight changes.
If I replace the three indoor timers/switches with wifi smart switches, can I then replace the outside timer/switch with a photocell device (or install such a device elsewhere) to control all four groups of lights with the single photocell?
closed as off-topic by Tyson, Machavity, The Evil Greebo, Daniel Griscom, fixer1234 Jul 13 '18 at 12:31
This question appears to be off-topic. The users who voted to close gave this specific reason:
  • "Questions seeking product or service recommendations are off-topic because they tend to become obsolete quickly. Instead, describe your situation and the specific problem you're trying to solve." – Tyson, The Evil Greebo, Daniel Griscom
If this question can be reworded to fit the rules in the help center, please edit the question.
    How do you want these lights to actually work? One photoswitch turning on and off all the lights normally, with individual manual overrides for each? – ThreePhaseEel Jul 12 '18 at 1:12
  • Yes. Exactly as you have suggested. – Brad M. Jul 12 '18 at 1:18
  • How many wires are running between the locations now, and is pulling new wire an option? – ThreePhaseEel Jul 12 '18 at 1:24
    Product recommendations and shopping questions are off topic. That said Visit smarthome.com, Insteon will do what you want with one exception, there is no photocell in the standard Insteon branded products, however with the hub you can program ‘Sunrise’ and ‘Sunset’, which are recalculated daily based on your location. – Tyson Jul 12 '18 at 1:24
  • Sounds really good. I'll check it out. Thank you. – Brad M. Jul 12 '18 at 1:47
As @Tyson mentioned in his comment, you can do this with most smart switches as long as you have a hub to set everything up. Most smart switches nowadays operate on several protocols (Z-wave, Zigbee, etc) and many hubs handle multiple protocols as well, but just make sure your switch and hub both use the same protocol.
In the setup of the switches, just program them to come on at sunset and off at sunrise, which will be calculated based on your location.
Alternatively, if you don't want to use smart switches, you can get semi-smart timer switches that will automatically adjust, based on your latitude, for sunrise and sunset. I've used this one in the past and it's worked great, although there are others on the market as well.
