So I had an old panel and subpanel replaced with a single new panel. The guys reused the old breakers, and the breakers wobble in the panel like loose teeth. With the old panel, they didn't wobble at all.
Is this because the breakers don't fit the new panel, or were they just not tightened down enough?
The breakers are GE type THQL, 1 pole units. The panel is a GE PowerMark Gold Load Center, type 1 indoor enclosure, model 6.
