In the few times I have replaced bricks in my home, I always feel the end result is a little messy. Specifically, despite my best efforts, the brick face ends up a little "smeared" with mortar. What is the best way to avoid this problem?
I thought this would be a common issue and searched online. Maybe I searched the wrong terms, because I mostly found references on how to clean up cured mortar (Muriatic acid).
In my case, I am talking about fresh mortar as the brick is laid. I am curious how Masons end with a nice, clean finished wall. Is it just experience and ability to keep the bricks clean in the first place? Or is there a washing / finishing step?
Both of those things. Skilled masons drop fairly little mud, and they manage to keep from smearing it. There's often a cleanup phase involving acid, though.
You can keep a nylon brush and a bucket of water nearby and scrub periodically, before the mortar cures. If you give the joints a few minutes to firm up and work carefully you won't damage them.
  • wow, I had no idea acid wash was a standard step. Sounds a little involved for anything more than a couple of bricks. I guess that's why they high fresh grads, like @Lee Sam. For me and my one-or-two brick repairs, I think I'll just try the nylon brush with water, and live with any mortar that doesn't take off.
    – Roberto
    Jul 13, 2018 at 1:57
Ahhh...one of my first jobs after high school graduation. It’s hard work, but any brick can be cleaned. Follow this site:
https://www.doityourself.com/stry/bucketbrushcleaning
Dilute the acid according to the manufacturer’s recommendation. BTW, keep the wall surface wet or the acid will burn (discolor) the surface.
