I'm trying to stick on anti-pigeon spikes on top of my window air conditioner and want a non-permanent solution that I can take off when I put it into storage.
Is there something I can use that's weather-proof but also removable at the end of the season?
    Hook and loop systems (often called by the brand name Velcro?
    – bib
    Commented Jul 10, 2018 at 11:07
    Yo magnets, yeah! Commented Jul 10, 2018 at 12:58
  • Silicon Caulk works great Commented Jul 10, 2018 at 13:56
    superglue super magnets to the bird strips; super easy.
    – dandavis
    Commented Jul 10, 2018 at 16:50
  • I'd be a bit concerned about magnets wearing through the paint due to vibration. Maybe use some vinyl sheeting between.
    Commented Jul 10, 2018 at 18:49
If you don't object to a product with an analogue in hook and loop tape, but more durable and substantially stronger, consider to locate 3M Dual Lock tape. It's available in various widths and lengths as well as different adhesive types. The strongest stuff has a gel type of adhesive, not quite foam, but squishy in a fashion.
The pieces are not "gendered" as with hook and loop. The tape has tiny stalks with mushroom heads that engage the other mushroom heads (get your mind out of the 60s here!) to form a very strong bond. The adhesive is weather resistant but I'm not so sure about sun resistance.
You'd attach one piece to the spike and one piece to the cleaned surface of the air conditioner.
The magnet idea is a good one, as you'd need only one magnet if your air conditioner has a steel casing.
I think I'd bond the spikes permanently to something heavy as a base, like nylon blocks, using screws or whatever. I'd then apply rubber feet to the blocks and simply set them on the air conditioner.
No need to rely on tenuous adhesive connections and no need to replace the fastener each season.
