My bathtub has a pull up valve that’s supposed to channel the water from the bathtub faucet to the shower head but it leaks a lot of water out of the tub faucet when the shower is on. What’s wrong and how do I fix it?
closed as off-topic by Machavity, Daniel Griscom, ThreePhaseEel, The Evil Greebo, mmathis Jul 10 '18 at 13:03
This question appears to be off-topic. The users who voted to close gave this specific reason:
  • "Not enough information was provided to answer this question accurately. Please include the make and model of all devices and equipment, photos, diagrams, drawings, and any other information that might help people provide an accurate answer." – Machavity, Daniel Griscom, mmathis
If this question can be reworded to fit the rules in the help center, please edit the question.
    A picture would help a great deal here. All you've done is describe a generic setup. – Machavity Jul 9 '18 at 23:12
I take it from your description that the diverter is in the tub spout and so it leaks out the spout into the tub. The leak is not going into the wall, right? This type of diverter does leak much more than the diverter inside the wall, but the leak is of no real consequence.
But if the leak is really excessive or it bothers you, then AFIK the only solution is replacement of the spout. AFIK there is no replaceable seal inside Sometimes it's metal-on-metal in the spout and the sealing surfaces wear with use.
See video.
    +1 exactly right (except that they are not all "metal-to-metal" anymore, some incorporate a rubber gasket; but still no replacing parts. You have to swap the spout). – Jimmy Fix-it Jul 10 '18 at 4:11
  • I discovered my spout leaked in the wall because of a lack of teflon tape. IMHO you can’t use too much tape. – Lee Sam Jul 10 '18 at 6:07
