Hi Guys,
I am on my last connection in my new mother board replacement for my Carrier furnace. As I was trying to connect the wire in the top picture to the terminal it wouldn’t fit and the piggyback connecting the two wires nroke. I don’t think these two wires are the same “gauge.” (Does that matter?)
My question is this: can I buy this Amazon disconnect piece and connect each wire to it and then put it on the terminal? Thanks in advance for any help!!
    When you say not the same gauge what do you mean? Those spade connectors will handle a lot more than any 20 amp circuit can provide. After looking closer that wire is 16 awg so the 1/4" spade. With blue is medium. And it should be fine are you saying the blade is wider than the female? I have had times where I have had to make slight adjustments like open the socket, I usually use a small flat blade screwdriver and a small pair of needle nose pliers to tighten them up once adjusted – Ed Beal Jul 9 '18 at 7:34
It looks like you have two female spade connectors and a female-to-female connector, and that's the part that broke. The female-to-two-stacked-male connector you have pictured may work, you just wouldn't be using the female part of it.
I find that there are small differences between brands and things don't mate as well as they should. If the wires are in good shape and not too short, a lot of times the easiest thing is to just cut off what's there and replace with your brand.
I don't see any compelling reason to use two female connectors here - I might replace these with one female and one male so you don't have the connector to deal with. I'd also use the fully insulated connectors, just to be a little safer, less chance of accidental contact, shorts, etc., especially since it's line voltage.
You can connect these wires by any suitable means. Crimp on connectors are easy to disconnect / reconnect without tools but you could use a wire nut, lever nut, etc. - anything listed and rated for the voltage and current.
Keep in mind that a lot of crimp terminal products are NOT listed / rated for line voltage, aimed more at the low voltage of the automotive market. I stick to reputable manufacturers' brands.
The one you have pictured is a bit different. When you say replacement that is one thing - when you say connect the two wires to it as a go between interconnect - that is another thing altogether (which is what you seem to be alluding to as the item pictured is not a replacement - it does not match the wire above.
Generally these spade type fittings are of the same sizes (there are for sure a few different standardized sizes and what you picture is pretty standard). That said a screw driver blade can twist between the rolled ends to widen the spade a little bit and also a twist in the insertion area can open the spade a bit - so that it will fit on the terminal.
You did not post a picture of your terminal connection on the new board (post one please) - so it is hard to tell what is going on. The above procedure should be sufficient , unless you have a really odd ball size.
