Is this the correct wiring setup for nest.
Asked
Viewed
316 times
That setup looks pretty reasonable to me, but you should double check with Nest. Enter your information into their compatibility checker to get a proper wiring diagram. nest.com/support/article/… – mrog Jul 6 '18 at 21:36
Can you post photos of the wiring at the furnace or air handler? – ThreePhaseEel Jul 6 '18 at 22:10
I will try and post those tomorrow. The ac is currently working so I left for it to cool down. I just wanted to make sure that the jumper from W2 to E on the original diagram was ok for the nest setup. – user1307149 Jul 6 '18 at 22:12
I am thinking you really need to put the white wire on W1 and not W2. Your old thermostat had Emergency heat - the Nest will automatically supply this through W1 if I am not mistaken. W2 is Secondary heat or auxiliary - your original already has a Jumper W2 to W1. Your Red Rh wire - depending on system - probably should be connected to Rc - but I could be mistaken here. Your manual should state whether Rc becomes live with 24Vac or Rh. Typically in a T-stat like this if you do not have another Rh red wire, Rc is almost always used . – Ken Jul 6 '18 at 22:24
