Hi I have a concrete porch with peeling and cracking paint. Do I need to sand it and then power-wash it before repainting. I tried using an orbital sander with 60 grit sandpaper but it just kept peeling and peeling. I was out there for an hour and no luck at all. I am desperate to find a solution and would rather not hire a painter? Some pictures are below:
Cement Patch on cracks & peeling paint
Holes where termite treatment was done
Close up of peeling paint
    Hello, and welcome to Stack Exchange. If the current paint isn't adhering well, then after adding another layer you'll just watch both peel off. – Daniel Griscom Jul 6 '18 at 1:42
  • Yes that is what I am afraid of. I am going to rent a belt sander with 36 GRIT sand paper and shred it off. – Jagst3r21 Jul 6 '18 at 2:42
    Why not get a wire brush attachment for your drill and do it the easy way? You can use paint remover as well - the expensive kind $15 a gallon works fantastic. – Ken Jul 6 '18 at 22:14
