I'm looking to seal an opening in a metal refrigerator with a standard heatsink as a part of a thermoelectric cooling setup.
It'd be ideal if there was a bonding material of some sort that can squish down, needs to be both heat and cold resistant (40 F to 120 F), can be cut away or dissolved in the future for repairs, and form a mostly airtight seal.
Please advise, thanks!
From your description, I'm visualizing that you want to attach a cover (metal to metal). If the parts mate well, superglue (cyanoacrylate) may do what you want.
  • The original thin liquid type works best when the surfaces make good contact so that there is a very thin layer of adhesive between them. Such a joint will be close to airtight. It doesn't work well as a filler.
    There are several types of superglue gels. One type typically has fumed silica as a filler, which will join poorer-fitting pieces by filling small gaps (but they still need to mate well). This may be a little harder to separate, if needed. Another type of gel uses a material like rubber as a filler to also make it more shock resistant. That will be much harder to separate, so you probably don't want to use that.
  • The glue has great strength for keeping pieces from being pulled apart, but very low sheer strength. When you need to separate them, you can sheer the joint by tapping on one of the pieces in the direction that would slide it.
  • It works well when mating two surfaces of the same material so that they expand and contract at the same rate. With dissimilar materials subject to temperature changes, the expansion of one relative to the other will sheer the connection.
  • It dissolves in common solvents like acetone. You can also separate the parts by letting acetone wick into the joint, and you can use acetone to clean the parts for reuse if you need to separate them.
  • 40 F to 120 F is well within its service temperature range.
Silicone will give you the squish and sealing you’re looking for, will hold up well with temperature changes, and can be cut and scraped away later if necessary.
There are silicone sealants made for automotive applications that would probably be best here considering the wide temperature swing.
Like this one, used between metal parts that are bolted together and need to contain a fluid.
 blue rtv sealant
    I would use rtv a bead around the hole will seal and hold the plate to the fridge, to remove slip some dental floss between the plate and fridge and it will cut the etc, just be careful not to cut into your supply cable. – Ed Beal Jul 5 '18 at 14:38
Not the answer you're looking for?Browse other questions tagged or ask your own question.
