In the living dining room several outlets and two overhead lights are dead.
At the service panel I checked all the circuit breakers outputs for power, and all are live. I also checked every GFI circuit in the house I could find and tripped and reset them all. I still have no power on the aforementioned circuits.
I also loosened and tightened each breaker screw holding respective wires, both at the breaker switches and neutral wires.
Still no power.
  • Are the outlets in question wired using the side-screws or the backstabs? Jul 4, 2018 at 19:15
  • Hello, and welcome to Stack Exchange. Has this always been the case? If not, what else changed? Jul 4, 2018 at 20:08
Are all the outlets / lights on 1 circuit, If so find the last working device from the panel or the First non working device, I find back stabs are the cause for this type of problem in the high 90%. In this case the failed junction may be at a light switch where the outlet is also powered via a splice before the switch, the other possibility would be where a outlet feeds the switches. As I said at the start most times I find this problem it is from a failed back stabs in a 15 amp circuit. I have found both 15 & 20 amp circuits that have had a loose wire nut or a broken wire usually right at the point where the wire was stripped. These are the main failures I have found over many years with daisy chained circuits.
