I framed in a new doorway on a load bearing wall. All went well until i stupidly enter image description heredecided to toenail the jack stud into the bottom plate, but after I had cut out the entry from the bottom plate. the result was a split bottom plate. I PVA glued and clamped it back together, but will the inspector be satisfied? is there some sort of bracket I can use to fix this? what other options do I have?
Looks good, keep going. It will not be a problem.
