I screwed up. I'm usually pretty good with PVC. I used the approved cleaner and primer, and Weld-On 705. I've done this dozens of times.
But here's where I screwed up: one part was a threaded bushing: 1" glue to ½" NPT. I made the mistake of turning in a petcock before the glue cured (nominal 20 minutes).
All the other ~20 glued joints are fine under pressure, but this one bushing is slowly dripping from two or three spots.
I really don't want to re-do the entire assembly, which is what it will take to replace this one bushing.
My spouse suggested a hose clamp. I thought of using a hypodermic needle to squirt some additional 705 around the spot where the bushing meets the "T" fitting. Either of these have merit? Any other ideas?
    You probably have to redo it. Can you cut into a piece near the the leaking fitting to replace it but still keep most of the pieces you have already assembled?
    – auujay
    May 7, 2012 at 2:30
  • With two splices and a new "T" and bushing, I can do it. But the leaking has slowed considerably, and it's not a particularly sensitive environment (cement floor), so I'm going to continue to monitor it, rather than throw a bunch of plastic in the landfill. May 10, 2012 at 16:55
The hose clamp is right out. All you'll do is crack something -- if you're lucky, right away.
Likewise trying to inject PVC cement (705) is not a good idea. Even if you manage to plug the leaks, the majority of the joint is compromised. It will eventually fail, and the law practically says it will fail 2 hours after you've left for a 2 week vacation, etc. (^_^)
PVC is super easy to repair or replace, and hacksaws are cheap too. If it's a particularly difficult section of pipe, consider installing one or two unions, to make the repair easier.
Go ahead and rebuild that section properly.
  • My problems are: 1. environmental: I don't want to bring new plastic into the world, and don't want to put more plastic in landfills. 2. cost: I'm living very simply, and I'd rather put the money from even these simple parts into other things. 3. effort: I've got six baby goats and 12,000 seed starts in the greenhouse to care for. The leak has slowed, and I'm going to monitor it. I don't get off the farm much, and can't remember my last vacation... (Too bad this site shares Faceplant's hatred of line breaks. I had to copy line breaks and paste them here to format this comment.) May 10, 2012 at 16:58
You'll want self fusing silicone tape. Dry it. Wrap it. Pressure test it. Done.
