I love the treads on these stairs which I will be revitalizing. The risers are awful. I was thinking of adding a nose and then using 1/4 be needed plywood to cover the treads. The wall right next to the stairs had an orange peel texture and if I add plywood it will be higher than the wall. The steps change site tionand the rest of the flight has walls in either side and isn't an eyesore. Its just 4 steps that need help.
Any suggestions would be super helpful! Thank you!
