Just got a block plane from Lowes (the only one on the display). It has a cup on its sole. Is it supposed to be like that?
Take it back. The bottom of the plane should be totally flat within the reasonable ability to measure flatness.
  • Fully agree that it should be flat. It could be lapped but since you just purchased it take it back.+
    Jul 2 '18 at 13:24
  • @EdBeal - If he had access to a surface grinder that plane could be fixed. Hand lapping it would take forever. Another thing is that seeing that the plane had such a dip in its base makes one wonder if the rest of the plane had good surfaces. For all we know the blade could even rock when placed into position.
    – Michael Karas
    Jul 2 '18 at 13:53
Most hand planes you buy unless you get a premium hand plane you need to tune. There are several tutorials online on how to do that. http://www.instructables.com/id/Tuning-a-Hand-Plane/
I normally take plane apart and flatten the sole using a granite stone using higher number wet sandpaper, the water will keep the paper sticking to stone.
https://www.woodcraft.com/products/granite-surface-plate-9-x-12-x-2-a-grade?via=573621f469702d06760016cd%2C5764196e69702d6593000317
You can use a permanent marker on sole and when lines disappear your sole is flat.
You should also flatten the back of your blade using same technique.
To get proper bevel I prefer this tool.
https://www.woodcraft.com/products/veritas-mk-ii-honing-guide?via=573621f469702d06760016cd%2C5764196e69702d6593000317
I hope this will explain it in more detail.
Now this takes time but the rewards comes when your tool works as it should and you get crisp cuts each time.
  • i think it is a valid answer, the rules need to be made more linear Jul 2 '18 at 19:39
  • @1224 not sure which version of answer you saw first but when I wrote my comment the answer was literally 2 sentences with no links, definitions of terms, etc. It's been heavily rewritten since then. Jul 2 '18 at 19:43
    @TheEvilGreebo your comments was good I am new to answering questions in Stackexchange so thanks for putting me in the correct direction.
    – jstodberg
    Jul 2 '18 at 19:46
