I have a flat roof for my 1100 sqft home which I expect to replace or recover in a couple years. I'm considering whether I should mount an outdoor gfci electrical outlet, just coming straight up like this. Besides christmas lights, what other uses might I need it for? Good idea, bad idea?
closed as too broad by isherwood, ThreePhaseEel, mmathis, The Evil Greebo, Daniel Griscom Jun 28 '18 at 1:10
Please edit the question to limit it to a specific problem with enough detail to identify an adequate answer. Avoid asking multiple distinct questions at once. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
    Your first question is too broad, and your second is completely subjective. – isherwood Jun 26 '18 at 19:34
If you have any HVAC equipment mounted on the roof, you are going to be REQUIRED to have a GFCI protected receptacle next to it for service equipment. But barring that, I wouldn't do it: no need for it, waste of money, possible site for future leaks and then it will get in the way of the future re-roofing project.
    Right, from a practical point of view the fewer holes you have on a roof the fewer possible leaks. – Retired Master Electrician Jun 26 '18 at 20:12
    I left this part out: just use extension cords for the Christmas lights. Easily replaced, no roof penetrations, useful for other things. – JRaef Jun 26 '18 at 21:12
A better location, avoiding roof penetrations, better weather avoidance, and re-roofing complications, would be in your soffits. I power my gutter cables from them. Run an extension cord for holiday lights or occasional power tools.
  • I agree with soffits, the outlet gets protected and there is no penetration flat roofs are hard enough to seal and Christmas lights can be connected easily. – Ed Beal Jun 27 '18 at 14:03
  • Good thought but in my case, no soffit - I have a parapet wall which I think might be too short (4") for a convenient install – dabi Jun 27 '18 at 15:47
