I need to replace the wall plate under a window that itself supports half a dozen or so load bearing studs.
I have a pair of post jacks that I plan on placing atop the horizontal stud immediately in front of it. I plan on jacking two joists that connect to the wall in question. I then plan on cutting the target stud out with an angle grinder (set with a wood blade) and replacing it.
Good idea? Bad?
