There is some moderate deterioration and cracking in part of the exterior trim of my house. I believe the trim in question is cedar.
Looking for repair advice.
My thoughts were:
1) Get some epoxy wood filler (Abatron WoodEpox) and attempt the repair. My only fear here is that the decay seems to be fairly deep.
2) Attempt to find lumber of the same size. Use a multi-tool to cut out that section of trim ~ 3 feet from the corner and replace.
Are there any alternatives to what I was considering? Is it worth attempting the epoxy route?
Photos of damaged area:
