This house is in need of a lot of work. The biggest problem I have right now is the basement flooding. Had new gutters put in in the past month which helped a little but my biggest issue now is where past owners must have patch up the windows in the basement with some more concrete.
As you can see in the pictures, the water comes in throughout the cracks from where they placed the block of concrete to the foundation. There are two of these patches on the same wall in the basement. There is no French drain or anything going around the house. So my question is, what would be the best way to take care of this for the long run and not just a temporary fix?
enter image description here enter image description here enter image description here enter image description here
  • I can't tell from so far away how the window openings were closed up. Is that masonry or something else? – isherwood Jun 19 '18 at 14:07
  • I have added a closer image to show detail – Garret Jun 19 '18 at 14:13
  • Good, but I still can't tell. What are we looking at? Concrete or wood framing? – isherwood Jun 19 '18 at 14:17
  • The concrete foundation in the basement. – Garret Jun 19 '18 at 16:44
  • I asked specifically about the patch in the window opening. – isherwood Jun 19 '18 at 17:17
