outlet died awhile ago from plugging in an air conditioner, it killed the whole room plus the hallway. breaker initially wouldnt reset, so i left it until i could get new outlets.
replaced the suspect outlet, noticed the left tab wasnt broken off but the right was. breakers are all on now, but still no power to the room. replaced outlet is hooked up the same way the old one was but nothing still.
should i just check every outlet and look for a missing connection or could there be something that happened to this outlet/breaker from the higher load of the AC due to the fact the tab wasnt broken off? thanks.
