I have a new vent fan, but no instructions. The old van had a light and fan, and I have two wall switches for it. The new fan has a light and fan as well.
In my ceiling I have a black, white, red, and ground.
The new fan has a black, a white, a white and blue (both labeled 'light'), and a neutral.
Any suggestions on how to set this up? Thank you, enter image description here enter image description here
First of all, the "neutral" that you listed for the new fan/light is NOT a neutral, it is a ground. The standard colors are:
  • White = Neutral (you have one in the existing wiring, 2 in the new unit)
  • Green & bare = Ground (you have bare in the existing wiring, green in the new unit)
  • The other colors (black & red in the existing wiring, black & blue in the new unit) are all Hot.
1 - Wire nut all White neutrals together. Your existing wiring has one neutral because the fan & light are on the same circuit so they can share neutral.
2 - Wire nut Green & bare ground together.
3 - Wire nut Blacks together for fan switch.
4 - Wire nut Blue to Red for light switch.
    Thank you! I realized after posting I was using ground and neutral interchangeably, which obviously is not the case. – Merc Jun 18 '18 at 12:56
