Are there any charts indicating what type of joints are stronger than others? For example, how would one determine which of the following joints is stronger? Intuitively I'd say longer cuts increases surface area and torque resistance, therefore the peg is a trade-off of less surface area for more shear resistance, but mostly it just secures the beam while the glue dries. Probably 4-8 screws would be better than the peg. The block is a poor choice because it eliminates any lateral point of connection making the beam only as strong as the block..there is no opportunity to glue.
But suppose my intuition is wrong! What table(s) is/are used to gain assurance?
4x4 joints Here are my use cases (post-and-beam screened porch):
use case
EDIT: Thanks to @Michael-Karas I was able to understand that these splices aren't necessary thereby eliminating my concern altogether. The question still applies for perpendicular splicing but I think those patterns are already well established.
no-vertical-splicing
    This cannot be answered as asked because you need to specify how the load on the joints will be applied. Some items to consider: 1) Vertical or Horizontal orientation. 2) Load in compression to Axis. 3) Load in extension from axis. 4) Any lateral load. 5) Type of material.
    – Michael Karas
    Jun 17, 2018 at 20:25
  • Vertical only, 4x4 PT Southern Pine. I'm think a peg up/down the center of the two beams is better than these three choices.
    – Corey Alix
    Jun 17, 2018 at 20:52
For vertical orientation of PT 4x4 you should simply plan to purchase the timbers that will be used as posts full length. So if you need posts 11' 2" then purchase 12'. If you need 14' 8 1/2" then purchase 16'. In fact if you plan your overlengths right you can use the cutoffs for locations where you will need a short piece such as over the door or for lookout blocks.
There are really no real good strategies to splice a vertical post when you can get the material that you need. Spliced posts just cannot take the same lateral stresses that a non-sliced post can withstand. Plus there is the consideration that making splices is a lot of work.
