I have changed the cartridge on a tap and in the process have ruined the washer that sits between the very base of the tap and the sink, I am referring to the ring at the base in this image which is now split:
As a consequence water can now run below the tap and to the cupboard below. I don’t know what the name of the washer is below the tap, nor whether or not I’m likely to be able to source a replacement (I am aware that plumbers seem to suggest simply to replace the tap in situations such as this).
I don’t know the brand or model of the tap as it was installed in my house since new.
